Grinding/Squeaking noise from clutch
8 Jan 2005
Macclesfield
When driving at any speed theres sort of a grinding bearing noise which gets louder and speeds up as the car does. When i press the clutch pedal the noise goes high pitch until i re-enguage the clutch, at which point the noise continues. The noise stops when the car is stationary even if the engine is still running.
I can feel the noise through the clutch pedal and the noise is present aslong as the car is moving, even if the car is in gear, neutral, clutch in or out.
Any ideas? Clutch/driveshaft/gearbox?
Cheers
