Grommet monitor mounts?
8 Dec 2004
Hampshire
Hello again folks.
So I was always envious of you folk who have desks that you can actually managed to get to the back of using a mount or equivalent.
My desk is premade for dimension wise and right up against the wall.
However I have a hole in the desk to one side where cables go through.
The diameter must be... 3-4 inches or so?
So my question, are there any monitor mounting devices that can be connected through the grommet hole (that can carry say a 10kG monito like a 35" widescreen?)
Wow didn’t realise! Thanks.
Would there be any ones that support 35” widescreen circa 10kg or so?
I like the ones that are fixed rather than adjustable, I find with me the adjustable ones ( gas etc ) tend to wobble when I type, lol. And most of the cheap fixed ones will easily support that weight. I think it is safe posting this on the forum because OKUK don't sell this sort of fixed type...
https://www.amazon.co.uk/Eono-Singl...FhUl4VwMzbE4fw/w==&smid=A1KNOLNIMGPL7O&sr=8-9
The more advanced ones that OKUK sell, well, you can look at for yourself. They have the advantage that you can move the monitor more easily but I am not sure whether they sell one that can be mounted through the hole in the desk.
https://www.amazon.co.uk/Eono-Single-mount-monitor-bracket/dp/B082D6ZTS1/ref=sr_1_9_mod_primary_lightning_deal?dchild=1&keywords=grommet+monitor+mount&qid=1611673917&sbo=Tc8eqSFhUl4VwMzbE4fw/w==&smid=A1KNOLNIMGPL7O&sr=8-9
Purchased a similar one to this with a shorter arm.
How in the hell did I not know about these before?
My wife came into my office whilst I was finalising the setup.. and she looked at the monitor in suprirse but also shock.
She thought I had mounted the monitor against the way but upon closer inspection she can see thae mounting kit.
Needless to say she was impressed with my pole.
*Gets coat...*
