19 Jan 2009 at 21:17 #1 mattyy mattyy Associate Joined 3 Dec 2008 Posts 491 Can any body please tell me where I can get hold of, even tell me the name of this grommet? Thanks =)
20 Jan 2009 at 09:16 #2 misterPK misterPK Soldato Joined 18 Apr 2007 Posts 3,736 Location Probably in a river somewhere It will be one of these, a lian-li PCI cooling kit. They do a 120 and 140mm version, but that one looks like its the 140mm one. http://www.lian-li.com/v2/en/product/product04.php?cl_index=2&sc_index=34&ss_index=83 PK!
20 Jan 2009 at 12:27 #3 EsaT EsaT Soldato Joined 6 Jun 2008 Posts 11,634 Location Finland 12cm fan version (BS-03) has been available from some central European shops for few months, BS-06 seems to be still unavailable.
20 Jan 2009 at 17:39 #4 mattyy mattyy Associate OP Joined 3 Dec 2008 Posts 491 I probaly didnt word my post correctly. Im actually after the rubber 'grommet', the black circle thing with the wire going through it in the middle. Im having a hard time finding on, mainly because I have no idea what they are called. Only place Ive really seen them is on towel holders... Anyway thanks for the link, might have to try and find a shop that sells it
20 Jan 2009 at 22:55 #5 Pred Pred Associate Joined 13 Dec 2008 Posts 323 Think they are called cable sealing grommets. High steet electronic store sells them.
24 Jan 2009 at 14:18 #6 mattyy mattyy Associate OP Joined 3 Dec 2008 Posts 491 Thank you, I will have a look next time I see an electronic store
