- 25 Jul 2011
So, I am about to build a PC for myself, one of the things I am really nervous about, and don't fully understand is all the posts I am seeing about being grounded as you build, for example the topic titled
Swapped pc from one case to another, now doesn't work
(http://forums.overclockers.co.uk/showthread.php?t=18301344)
A few questions
Firstly - Say you are building an £800 rig, and you do this, and you have a bunch of components so cant tell which one is damaged, are you effectively down £800?
Secondly - What is the best way to avoid this happening, and does it happen very often? I have seen on the "System Build Guide" post, something about having the power plugged in but not switched on, what does that mean, the power socket for the PSU plugged into the Mains, but with the mains Switch off? (Let me know if u don't get what I am on about)
Thanks
George
A few questions
Thanks
George
usually wooden floors and if I am fixing a friend/family pc and i have to be on a carpet then the socks will come off but this is a rarity.
