Have disabled right click on desktop/start menu but users can still right click the little icons on the system tray. Anyone know the option for where that is ???
I need to disable the right click ability. There are several system tray icons which allow the user to change display properties and other such like which they aren't allowed to have access to.
Right click is disabled for desktop and the taskbar but they can still right click on the system tray icons.
What can they do with sys tray icons that you dont want them to be able to? Maybe you should look at making things not appear in the sys tray even to start with. Might be easier?
