groups management
3 Dec 2002
Groovin' @ the disco
Hi
I need to see what members are in a local group, I'm ssh into the machine at the moment, but can't find the command to do it, also is there a way of using a GUI to manage local groups on a local/remote machine?
Thanks in advance.
dscl . read /Groups/[group name]
will tell you the info about the group and then within that info is Nested Groups. Google the code and it should tell you the group name.
