Groupset Advice
20 Sep 2009
Brighton
Hi guys,
Recently had a chat with a bike mechanic after I found the middle cog of my crankset is pretty bent up after snapping a chain :( He suggested just getting a new groupset, as the bike is 4-5 years old Giant Defy and would provide a decent upgrade by spending £300ish.
This got me thinking about just selling up for £200ish and spending £500 on a new bike. I started looking into groupsets, but is there a list somewhere that tells you about all the different Shimano versions and what their names represent, and how good they are?
Finally, any suggestions for a £500 roadbike? :D
http://www.winstanleysbikes.co.uk/p...d_Frame_52cm?gclid=CI6z0qnBjM8CFRPhGwodA-kG8A
Roux Vercors R7 2014 Bike
Frame: 7005 double butted alloy
Fork: High carbon ferrous alloy
Cranks: FSA 50/34
Rear Derailleur: Shimano 2300
Shifters: Shimano 2300 16sp
Cassette: Shimano 8sp cassette 12/25
Wheelset: Triple chamber aero rims, Q.R hubs
Tyres: C.S.T 700x25
Brakes: Tektro
Handlebar: Kalloy anatomic
Stem: Kalloy ahead road
Saddle: DDK Race
Extras: Full gel bar tape
not super top end but a lot of bike for the money.
BIG image.. http://www.rouxbikes.co.uk/wp-content/uploads/2015/12/roux-2014-vercors-r7-road-bike.jpg
Very helpful, thanks!
I'll check it out, thanks!
Oooh, that Ribble looks sweet! With all bike manufactuers claiming to make awesome bikes, and aside from the groupset, fram material etc., how am I supposed to decide which is 'best'? Pick the prettiest one? :confused:
What are you going to be using it for? Commuting? Sportives? Recreational weekend rides? Lots of climbing etc?
Wheelset, tyres etc are all factors to consider at this sort of price range when trying to get the most bang for buck.
If you're confident enough to buy used or have someone you trust to give a second hand bike a look over your money will go further. Though buying new from a LBS will help resolve any issues and normally get you a free fit too.
Just evening/weekend outings really, doing between about 20-100 miles. I've got a brand new pair of Schwalbe Marathon Plus tyres on my bike at the mo. The bike I have is second hand, but I don't know the history or last service. I figured that spending £80 on a service and £300 on a groupset meant buying new would probably make more sense.. Having got any friends selling unfortunately :(
