Grr... bloody pc..
4 Sep 2005
London
Having a bit of trouble with this computer...
Was playing MTA:SA earlier, and my computer just randomly restarted. Twice.
Later after that it was ok. So i went for a bit of BF2. Every server i join in BF2, i lose my connection to. So i try forwarding the ports on my router. After i did this, BF2, fails to load.
Then my PC restarts again :o
What the hell is going on?
Princey said:
Do you have any dodgy processes running in the task manager? Also make sure you PC isnt overheating.
My pc isnt overheating, the GPU temp is never above 50, and CPU at load is 47.
I've checked the processes, and the only odd one is called something like tempE5.exe or something, but i think its normal. :(
Have you run a spyware program to make sure? Have you tried updating all your drivers? Also download the latest chipset drivers for your motherboard from here .
