Hello guys
I have a pc from a work colleague, I think I got the problem but ran into another one. When I removed the heating the CPU went with it..
and was stook fast to it. I didn't bent or break any pins, so win. However, I tried to put to remove between the best spreader and heatsink. When I removed the mode guess what happened....
yes some dropped off the nossel and went were the pins are. Typical.
Is this stuff conducive, its artic remover... if so I gotta let it dry off, I don't wanna risk a new mobo and the CPU.
You can guess what platform if the CPU got stuck to the cooler
Yes I did get them parted with a bit of gental
pursation
Okay I did bend a few when the CPU went with the heatsink
pursation
