grr, wu 3days
6 Oct 2004
England
Grr just finished my first ever wu, it took 3 days (well 6 because pc is on 12hours aday)
Its just start another one, guess what, same dam time to do it :(
I set up 20 borgs this week and half of them got 212x projects. As they're only on for about 8 hours per day and weekdays only, I don't think they're going to help me all that much.....
wait til you get a 1498, i've got one at the moment. its 20% complete and has 8 days to go. It might be worth 805 points but at 10 days to complete on a 2.8ghz xeon is a bit much
There's probably something wrong - most likely it's not using SSE as it's had a dodgy shutdown of the client previously
look in your log for when it started processing the WU and you should see...
[07:44:37] Writing local files
[07:44:37] Using table 1
[07:44:37] Extra SSE boost OK.
If you don't see that then it's using standard loops and will be going a lot slower than usual.
Code:
[05:19:45] Protein: p1498_TETHERED VESICLES
[05:19:45]
[05:19:45] Writing local files
[05:20:50] Extra SSE boost OK.
[05:20:55] Writing local files
I think the estimate is off in famon, by my calculations it should be more around the 6 day mark.
