6 Feb 2007 at 22:36 #1 Colbaker Colbaker Associate Joined 8 Dec 2004 Posts 1,970 Location Paignton, Devon i am running Vista Premium 64bit Version and can't get Transcode 360 working at all, either streaming through the Xbox or even on the Desktop Anyone tell me how to install this and what codec packs to install? Thanks
6 Feb 2007 at 23:39 #2 Lister2020 Lister2020 Associate Joined 22 Jan 2007 Posts 314 FFdshow is the only codec pack you should have. transcode360 (vista) WILL NOT WORK on the media center itself. Only on an extender. How bout you tell me the error message you are getting when trying to transcode a file.
7 Feb 2007 at 00:25 #3 blighter blighter Soldato Joined 31 Mar 2006 Posts 3,272 Location Gravesend, Kent goto C:\Program Files and set the Transcode 360 folder permissions to "anyone"
7 Feb 2007 at 00:26 #4 Scottland Scottland Soldato Joined 18 Oct 2002 Posts 15,723 Location North Wales If you using Vista x64, then you may need the Vista Codec pack with x64 addons. http://www.msfn.org/board/index.php?showtopic=66826
7 Feb 2007 at 22:04 #5 Colbaker Colbaker Associate OP Joined 8 Dec 2004 Posts 1,970 Location Paignton, Devon the error message is, "unable to queue video file for transcodig and streatming" this is on the xbox.
