GRRRRRRRRRRRRR!! ASSASSINS CREED HELP PLEASE! lol
1 Sep 2007
Hey guys, just started to play this again and im on memory level 4 , where you have to kill those 3 dudes.
Ive done all the eagle view things in each city and rescued all the civilians, but now I have a blank map with no icons to find the 3 people.
Where are they, and why isnt it showing up on the map?
Thanks a lot in advance guys, its really annoying me!! :D
Yep same happened to me, all you need to do is walk the outskirt of the boundary of the cities your in. You will then find an opening into the next part of the city. Then you just fins another high point and more will become available.
There'll be places on your map that are unexplored but aren't blocked off by the memory barrier thing, just gotta look round the edge.
Same happened to me lol, was confused for ages, had to check some online guide.
this was the only thing that provided any kind of longevity in this game for me
i ended up just traipsing around whacking fools for about 5 hours then i found a viewpoint i hadnt climbed
loads of people got stuck on this cos the game doesnt explain it properly. All you have to do is go into the unvieled parts of the map and look for new lookout points, these wont be marked on your map. They will be obvious because they are high points and have eagles flying around them. Once you have found a few of these, everything will be back to normal and new objectives will show on your map
