29 Nov 2011 at 09:38 #1 Mansnake Mansnake Associate Joined 8 Mar 2010 Posts 84 Hi Guys, Seem to have a bit of an issue. I can no longer see 'USB Settings' on the GS2 just 'USB Utilities' see pic Anyone seen this before ? Cheers guys
29 Nov 2011 at 10:34 #2 Myshra Myshra Soldato Joined 26 Mar 2010 Posts 4,635 Location M4 Corridor Maybe I'm missing the obvious but what are you wanting to do/change?
29 Nov 2011 at 11:43 #3 iamtheoneneo iamtheoneneo Soldato Joined 15 Mar 2010 Posts 11,542 Location Bucks usb settings? what are they? never had that on mine.
29 Nov 2011 at 11:48 #4 Mansnake Mansnake Associate OP Joined 8 Mar 2010 Posts 84 im trying to connect to kies. On the galaxy s there were usb settings where you could change it between kies connection and usb storage device etc... on the galaxy s 2 is kies connection just wifi now and no cable option ?
29 Nov 2011 at 11:55 #5 kona786 kona786 Soldato Joined 25 Jun 2007 Posts 22,835 Location Downtown make sure usb debugging is off then connect as normal
29 Nov 2011 at 13:49 #6 Myshra Myshra Soldato Joined 26 Mar 2010 Posts 4,635 Location M4 Corridor Mass storage: Settings > Wireless & Network > USB utilities and click the button > then (and ONLY then) plug in USB cable says google. Kies is just connect and it automatically tries to connect via kies iirc.
29 Nov 2011 at 14:13 #7 Mansnake Mansnake Associate OP Joined 8 Mar 2010 Posts 84 Thanks guys. Kies is detecting something then it says 'Device is not supported' which is gay. so im un-installing kies and then installing again. thanks for your replies.
29 Nov 2011 at 14:49 #8 Myshra Myshra Soldato Joined 26 Mar 2010 Posts 4,635 Location M4 Corridor You need the samsung USB driver, a google should give you it.
