- 15 Apr 2013
- Ireland
Does anyone have any ideas\hypothesis as to why these Skylake 6700k Cpu/DDR4 clocks are dropping to around 25% when I use my XMP profile with any sort of overclock on my GA-Z170X? Temps are below 65C and I have both auto and manually set multipliers/voltages/timings of DDR,Core,VCCIO,VCCSA and LLC.
core speed______XMP Enabled?_________ SA clock_________Realbench Percentages__________Realbench score___________Notes_____________________
4.0(4.2)________No / 2133 Mhz__________1.0 Ghz___________105.96%____________________121269_________________Stock everything.
Ghz___________Yes / 3200 Mhz__________1.0 Ghz___________109.79%____________________125562_________________4% improvement +4300 score.
1.2v
4.4____________No / 2133 Mhz__________1.0 Ghz___________114.7%_____________________130669_________________10% improvement from stock, +9000 score.
Ghz___________Yes / 3200 Mhz__________1.0 Ghz___________108.27%____________________123920_________________worse all round than stock speed ddr4 and 4.4 Ghz + Xmp with stock speed CPU, cpu+ddr clocks dropping under load.
1.29v
4.6____________No / 2133 Mhz__________800 Mhz___________119.15%____________________136375_________________solid all round/very snappy. 15,000 over stock.
Ghz___________No / 2133 Mhz___________1.0 Ghz___________120.13%____________________137488_________________my top result of this test. Very impressive speeds in OS.
1.33v__________Yes / 3200 Mhz_________800 Mhz____________FAIL________________________FAIL___________________Posted once, would not re-post. Reset loop triggered, Needed CMOS cleared.
______________Yes / 3200mhz___________1.0 Ghz___________FAIL________________________FAIL___________________As above, Hangs and needs Cmos cleared, Posting B6 debug code-NVRAM cleanup.
Stock speed at auto voltage/1.35v ddr. VCCIO and VCCSA set to 1.2v or 1,25v for testing at o/c speeds.I generally use Cpu LLC level Turbo/5 = 0.1 variation idle to load verified. Any help is appreciated here, Thank you.
1.2v
1.29v
