GSKILL Keyboard suddenly not compatible?
18 Oct 2002
Behind you... Naked!
Ok, I have been running a few of my systems through a KVM.
Windows, Linux, Mac, and my Server, and I am using a GSkill KM780 FingerTip Interface and MX780 Rodent, and for a short while now, I have been using these just fine.
I have recently done a fresh install up to Mojave and for the most part, everything was just peachy.
Also, when I plug in another keyboard, that works just fine.
When I try to log in with the GSKILL, it shows me a little DOT instead of the letter I type as it should do, but then when I try pressing ENTER / RETURN etc, another DOT appears? - if I try BackSpace, another DOT appears? - I dont know what they are doing other than showing a DOT and I have just thought I could open up a note padf and see what the keyboard is doing and whether its trying to do the right keys I suppose, and so yeah, I will do that in a bit.
anyone have any ideas though for now, as to wTF its doing this for?
As I said, it was fine until a couple of days ago.
For what its worth, I have reinstalled Mojave and the G.Skill is the same.
Although, it has nuts keys instead of the normal keys
For example,e there 2 lines are the same text.
Top line is my Logitech G510s and the bottom line is the G.Skill KM780
Hello Darling
AOlssw;AKhyspun[
The [ at the end of the line was the Return key, and Capital H is the AO
I use a KVM and so this is hellishly irritating and it means that whenever I use the Mac, I have to also use a different keyboard every time.
Surely there is a cure for this out there?
