gskill ram dead
4 Jun 2008
west yorkshire
i just got a rma number from taiwan to send back my dead stick of ram,
but they say in eamail they want both dual chanell sticks rmaing.
but if i send both i wont have my pc working,so im just going to send the dead stick,will that be ok.:eek:
Depends what they send back.
They usually ask for both so that they can send you back matched pairs - which is the ideal. Plus, if one stick has died there's a slim chance the other may eventualy die too - same batch, same rig same conditions...
Also, they may not have the same memory in stock so they reserve the right to send you out something of similar quality or better. Which is great but if you only send one stick the returned stick may not match your remaining stick's voltage/frequency/timings... So, you may run into difficulties getting them to run together (differing voltages being the main issue).
I would email them and get further conformation.
thanks,ive emailed them.
ive just had email stating its strongly recomended to send them both,but im just going to send the one bad stick of G.SKILL F2-6400CL4D-2GB .as i will be with out a pc untill rma comes back,which could take weeks as its going to taiwan,
Honestly, I wouldn't risk sending one stick and having them email me saying to send the other stick before they'll send out a replacement, just send both back. The weathers been nice lately, go outside :p.
your wright,
suns out im in.
your wright,
suns out im in.
While you're in amend your sig.
It has one too many lines.
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
