GSX 650F disc lock?
disc lock is a disc lock. if unsure pop to the shop with the bike and before you buy it (if allowed) pop out and try it fits the disc holes but much of a muchness. try and buy one with a long shiny bit you atach to the handle bar as it can be expensive and embarrassing if you try and ride off with it still on. ;) not that i know... ;)
I use a motrax 'GUVNA' its large so easily visible and as such a deterrant, I say use I havent ever once put it on my current bike as it has a tilt sensor alarm so I would be able to hear if anyone moved it
