- 27 Dec 2002
- In ** bottom drawer...
So leading on from replacing the rectifier in the week..
Saturday I charged up the battery, bike started and ran fine.
I put a volt meter on the battery and saw it hold at about 12.23v and drop slightly under load but seemed to recover to 12.23v.
So off I go only to have all electrical power die about 2 miles from work - right opposite the houses of Parliament to be precise!
Bump started and go to Vauxhall bridge and no juice at all.
AA dude(bike specific) turns up, I explained whats happened and whats been done...
In his oppinion the generator has died and most likely the battery now as he said when running you should see 13v and never a voltage drop.
His logic was - when the rectifier goes it forces the generator to work over time and the battery as well which will expose any faults in the generator and battery due to the increased load due to the failed rectifier.
So when Ive run it with the new rectifier and not seen correct voltage under load its because the generator and battery are most likely FUBAR.
Does this sound right? Any particualr way I can test if the genny or battery have defo failed?
Im about to order a new genny and battery as I need the bike back asap, cant afford a garage to do the work and am missing out on some FINE riding weather!
Any help appreciated!
