- 23 Nov 2005
- Kingdom Of Fife
Hi All,
For gaming I normally just have GSync on for my Sammy Odyssey G7 monitor. I then if required lock the framerate to either 120 or 240fps depending on the game.
Quick question as I have seen many posts online regarding this, do you have VSync enabled also, if so from NVCP or the game itself. I was under the impression you don't need them both, but this appears to be contradicted and game dependent with regard to input lag.
Any advice or comments would be appreciated.
Spec in sig.
Spec in sig.
