Gsync/Freesync conundrum
3 Feb 2021
Hey pretty noob question here, thinking of getting a secondary monitor but it’s freesync and not Gsync. Question is, does freesync work with nvidia gpus? In the sense that, I am aware that I can enable Gsync from the nvidiau panel when freesync is enabled, but let’s say I turn gsync off in the nvidia panel but have freesync enabled in the monitor settings. Does it still do what Gsync is supposed to? Or is freesync exclusive to amd gpus? Thanks!
iirc 10xx series nvidia cards and onwards work with freesync. If you have anything older, you'll need gsync.
Yes. But question was whether it would work if I disabled Gsync in the panel but turned on freesync in the monitor settings using the monitor buttons.
I have one GSync monitor and one Freesync monitor on my 2080 Ti - and a non-sync monitor too - and both get the benefits of their respective technologies.
My Titan Xp (effectively a 1080ti) supported freesync, but I had some issues with my Acer 38" UW which while the monitor is not certified it kind of worked, however I would get a black screen for 2-3 seconds every now and again. The RTX 3080 has been pretty much flawless with the same monitor... Obviously you need to ensure you keep in the monitors freesync range, but when it works, it is really good!
Thank you everyone for your input! I took the plunge and got the monitor. Runs flawlessly with freesync.
Gsync will need to be turned on in the nvidia control panel for freesync to work, but yes it will work fine. Prior to going ultrawide had a Freesync and Gsync monitor hooked up to the same GPU
