GSync over HDMI 2.0 @ 1440p? Or FreeSync?
15 Nov 2003
Marlow
I run my 4070 thru an HDMI KVM switch which is HDMI 2.0.
If I get say a 144hz monitor which is GSync compatiable, is there any chance the 4070 will GSync to that monitor over the KVM's HDMI 2.0 to the monitor?
Failing that FreeSync?
Its unlikely you'll get GSync or Freesync through a KVM, can you not connect direct to the monitor and just use the KVM for keyboard and mouse?
Current monitor inputs:-
DP - Work laptop
HDMI - KVM with server PC and games PC
Guess if the monitor had two HDMI something could be done on that front, but obviously not as slick/easy to operate as a KVM to switch keyboard, mouse AND monitor ;)
DP - Work laptop
I would see if you can connect the work laptop to the KVM and use the DP for the games PC
