gt1850 volt mod
26 Aug 2010
glasgow
Hey 8 pack, quick question about your parvum build,
You used a volt mod on the gt 1850's down to 7 volts. Can you tell me how you done that?
In a 4 wire molex plug lead the yellow is 12v, the red is 5v and the blacks are ground, if you splice wires to make the red (5v) the ground instead you get 7v (12-5=7).
