Hi there.
So, I've recently been playing with Linux and after the painful process of getting bumblebee installed (Optimus completely buggers over Linux, even though it's useless and achieves nothing because it doesn't work) find out that the GT650m in my laptop doesn't appear to be clocking properly.
Apparently there's some bug in the driver software that reports the wrong speeds on cards. However, having played Mirror's Edge (Yes through Wine, not optimal) the performance was really quite lackluster. Being rated platinum for Wine, and everything working flawlessly other than performance, this leads me to think that the reported 405MHz on the card is true.
I'm on 304.84 at the current moment, the driver that defaults when I install Bumblebee. Other than this clocking issue, it seems fine.
So, you can't overclock a Kepler graphics card apparently because no utilities exist, I'm stuck in a rut.
Is there a newer driver that fixes this? Is there a way to upgrade Bumblebee?
Thanks
Thanks
