GTA 4
anywhere between 30-60 with everything on highest settings 1680-1050 except draw distance which is still impossible to max out till they make the game support sli or they make a single gpu with 1.5 gigs of vram or more. game very playable the constant shifting of fps causes some stutter though - would be smoother if you could limit the fps to 30
Blame ATi's drivers or Rockstar's coding for ATI GPU's, my 8800 spanks my 4870 in this game, its a night and day difference ! Smooth as butter as opposed to stuttery crap FPS fest.
1920x1200 higher settings with some tweaks so it looks no different to the absolute highest. shadows ion high.
Get 30-50fps depending on where the action is.
Smooth either way even 25fps+ which the latest patch sorted.
