gta 5 xbox 360 usb
16 May 2005
the hood
Hi,
i only have a 20gb unit i plan to put a 16gb usb in the xbox and install GTA 8gb install to there.
can anyone tell me if there will be any issues
the usb stick is
16GB SanDisk Cruzer Blade USB
Should be fine, although if you're buying one specifically it may be better to go for a 32GB one as that way you can install both discs and have some room spare for updates etc.
