GTA:SA Vehicles.
you need too mess around with the gta.img files iirc.
there should be a readme with the vehicles or a guide on the site you got them from
Dont install cars, come and have a blast on MTA:SA ! :D . i normally play on the 987+ maps server (think thats what its called). All you have to do is make sure you're version of gta:sa is v1.0 and then download mta:sa and your off. The mod dosent work if you have installed other stuff though.
www.mtasa.com
If you havent got a v1.0 gta:sa then theres a patcher somewhere that can make it v1.0.
