GTA SA with xbox 360 controller
22 May 2004
N.Ireland
Hi guys got GTA Sa and a 360 controller and am looking to know has anyone got any idea f how to set up the right hand side analoge so it will work as looking about?
Also I cant seem to get the two rear shoulder buttons to work.
Is their a config file or something for GTA SA I need?
Still cant get it working correctly. Anyone here got it working correctly?
Its causing major slow down in gta.
Any help would be appricated guys as bought this joypad for Gta
Gareth
The two rear shoulder buttons are not buttons but axis like your joystick they have a gradual state of movement as opposed to just on or off like a button so some programs will not recognise them as buttons
You could try xpadder this great little free program will emulate any mouse or keyboard command
so you can set one joypad to cursors to move and one to mouse to look around and you can set the shoulder triggers to any key you want
then just set gtasa to use that key for the action you want remember and set gtasa to keyboard and mouse controls and to use the key you have set up in xpadder
here is a link to the xpadder site
http://xpadder.com/
XBCD will let you use the shoulders as buttons or triggers, it's all in the config. They even supply config files for you to use.
