Sometimes it seems smooth sometimes its jerky sometimes stuttery, my gpu usage is all over the place it goes down to 50%
BF4 my usage stays between 98-100% and is smooth. That is with Mantle though, the only way to get my gpu usage to stay higher for longer in GTA is to up the graphic settings but then i get less fps, i have a 120hz screen.
In the Witcher 3 its the same sort of thing i have to up the graphic settings to get smoother gameplay, is this normal?
Thanks
BF4 my usage stays between 98-100% and is smooth. That is with Mantle though, the only way to get my gpu usage to stay higher for longer in GTA is to up the graphic settings but then i get less fps, i have a 120hz screen.In the Witcher 3 its the same sort of thing i have to up the graphic settings to get smoother gameplay, is this normal?
Thanks
