What temps do you get if you run the heaven benchmark on absolute max settings, on a loop for 10 mins or so?
Very strange shouldn't be that hot. Played for about 4 hours last night my max temperature was 82
What brand card do you have? Is it an MSI? A lot of people said the fans on the MSI 290's are useless
Are you using the stock fan profile? If so.. change that!
Good call! What can I use?
I've ramped the fan up so when it's above 80c it's 90%. Temps still hitting 88c though
No difference still climbing up to 88c
Maybe this is just a normal temp for the MSI 290's as they are known to run hot
