I Tried OCing my GTS450, GPU-Z says it's OCing, but my temps don't change and neither does Unigine Heaven 2.1
I'm using MSI Afterburner
Unigine
Heaven Benchmark v2.1
Binary:
Windows 32bit Visual C++ 1500 Release May 21 2010
Operating system:
Windows XP (build 2600, Service Pack 3) 32bit
CPU model:
AMD Phenom(tm) II X4 925 Processor
CPU flags:
3499MHz MMX+ 3DNow!+ SSE SSE2 SSE3 SSE4A HTT
GPU model:
NVIDIA GeForce GTS 450 6.14.12.6658 1024Mb
Settings
Render:
direct3d9
Mode:
1840x1036 4xAA fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
4x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Replication: disabled
Tessellation: disabled
Test 1
Core Clock - 1100MHz
Shader Clock - 2200MHz
Memory Clock - 2300MHz
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.2
Scores:
181
Min FPS:
3.7
Max FPS:
14.3
Test 2
Core Clock - 1150MHz
Shader Clock - 2300MHz
Memory Clock -2350 MHz
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.1
Scores:
179
Min FPS:
3.7
Max FPS:
14.1
Test 3
Core Clock - 1200MHz
Shader Clock - 2400MHz
Memory Clock - 2400Mhz
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.1
Scores:
179
Min FPS:
3.7
Max FPS:
14.2
Why is this happening!?
Unigine
Binary:
Operating system:
CPU model:
CPU flags:
GPU model:
Settings
Render:
direct3d9
Mode:
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
4x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Test 1
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.2
Scores:
181
Min FPS:
3.7
Max FPS:
14.3
Test 2
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.1
Scores:
179
Min FPS:
3.7
Max FPS:
14.1
Test 3
Fan Speed - 52%
Max Temp - 44C/111F
FPS:
7.1
Scores:
179
Min FPS:
3.7
Max FPS:
14.2
