GTX 1050 NVIDIA DRIVER CODE 43 and blue screen while installing
29 Jun 2021
Turkey
Hi guys,
I use Lenovo Legion Y520 , i5 7300HQ 8GB RAM and 120 GB SSD
But when i try update my nvidia driver i always get blue screen.
I tried DDU and reinstall fresh drivers which old and up to date but didnt work, i tried flash bios back then try installing up to date didnt work as well. I tried format tons of times , all my nvidia drivers are up to date.
https://disk.yandex.com.tr/d/VRd1ZL4qABZg3w
This is minidump file please help me !
Gpu core or gpu memory issues. most likely.
RAM the pc if under warranty, if no warranty find some one who does component level repairs.
If u can spare 10 minutes, watch this video. It will show you how we diagnose core 43 and dont assume your card has same issue. It is one of the possible issues.
43 Usualy means Core is unresponsive but can be memory issues aswel. But it doesn't mean your card is unrepairable. Sometimes they can be fixed.
U can run memtest. wont hurt.
If you not sure about your pc internals, you have two options. Learn what's inside your pc and how to take it apart, or take it to pc repair shop.
If u decide to learn, ask question here and u will find help. Utube your pc and see if u can learn more there.
I saw some solutions in internet who gets same errors like me. 43 error nvidia driver PAGE_FAULT_IN_NONPAGED_AREA in minidump 0x00000050 code and some solutions were about xmp but when i check in bios i couldnt find it then i have learned my pc has no advanced settings in bios menu. So im gonna run memtest after i buy new usb because i have only one and it has downloaded windows . But if i get ram error what should i do . Should i remove one and try to install driver and if i get error then try for same thing for other ram. Or what i am not sure man.
