GTX 1070 - Strange Multi Monitor Issue
22 Jun 2012
A few days ago, my main g-sync monitor (DisplayPort) turned off leaving just my secondary monitor (HDMI) working.
If I unplug my secondary the g-sync monitor comes on fine, and if i plug the secondary back in that comes on and my main turns off again.
If I reboot the boot screen shoes on my main monitor?
I have tried uninstalling all drives (With DDU) and installing a older set of drives but that has not done anything, is this a sign my GPU is on the way out or just some odd bug?
Another strange thing, when I plug my second monitor it I get the pop to say a g-sync monitor has been connected.
What happens in clone mode?
Well, I tested that and put it back to extend it this has solved the issue.
Seems for some reason Windows decided to switch to "Show only on 2" ? not sure how that happened!
Not sure why i didn't check a simple setting like that :D
Thanks.
Thanks.
easyrider rides again..:D
