So i have a few questions regarding my upcoming purchase.
1. I've read around and found most Ti hit their OC limit around 2000-2100 mhz core. Is that true and mean the cheapest 1080 Ti will do the same job compared to the more expensive ones.
2. My 1070 gigabyte highest oc is 2126 mhz but throttles down to 1950 mhz unless i keep fan speeds above 70% and temps below 60. Would a hybrid 1080 Ti solve this issue or would i be better off saving the cash?
3. I currently have a AX 760 with a 5820k OC to 4.6 ghz. If I were to purchase 2 in SLI which PSU would i need to upgrade to?
4. Would my cpu bottleneck them in SLI @ 1440p/165hz. (Just making sure)
5. Is it even worth it to SLI @ 1440p/165hz?
TIA!
TIA!
