GTX 260 - CPU limited?
Ya, same just black:p Fits snug, about 5mm clearance between end of the card and hard drive cage. Also take off those crappy PCI clips and use the screws. I had trouble getting my last 4870 in with them on which is only like 9", this bugger is 10.6", with the clips off you can slot it in no hassle.
might have to move some hdds out then as i have 3 and the 8800gt i have made me move one will see what happens. thanks for all the help m8 really helped me out.
time to look in to overclocking now do u have msn or anything so maybe i could call on u for help if poss if not m8 its cool
