I bought a Zotac GTX 260 Amp! edition last week (55nm, 216 shaders) from OcUK. It was factory overclocked to 650 core, 1400 shaders and 2100 memory.
For the first few days I only played Wolfenstein Enemy Territory (hardly taxing
) and didn't notice any problems.
Then I installed Grid which came with the card. I had problems with that as soon as I started playing.. graphics would pause for 2 seconds at a time, screen would go dark then light and it would eventually crash.
I played some COD:W@W then. No apparent texture issues with that but it always locked up within 1/2 hour leaving a static image on the screen with funky colours.
Then I played some Half Life Ep2. In certain parts of the game I got texture problems.. some flickering blockyness and other textures that just flickered at random.
I decided to run Furmark to see if it was stable, so I set it at 1920*1200 with 16xMSAA and ran it in stability mode for an hour... no problem
The GPU temp maxed out at 79c in that. The card is receiving all the cool air from my 120mm intake fan without any obstructions. Also there were no visible problems with Vantage, although I only ran that once.
I was originally using the 182.08 drivers, so I tried the 182.06 and 181.22 sets (all on a fresh install of Vista 64) but had the same issues with all of them.
Then I installed RivaTuner and underclocked the card to the 260 default clocks. No problems with any of the previously mentioned games
I game at 1920*1200 and usually have 4X AA and 8X AF enabled in most things.
Should I RMA it? Is there anything else I can do to conclusively prove the card is at fault? I don't really want to go to the trouble of RMA'ing the card only to have someone run Furmark/Vantage on it for an hour, decide it's ok and send it back to me.
Edit: This is the first piece of PC hardware I've ever bought that I've had a problem with. Maybe I should have heeded the warnings about buying a factory overclocked card
