GTX 260 Signal problem
4 Mar 2007
Essex England
Hi
Took delivery of a Gigabyte GeForce GTX 260 on the 11th of August from Overclokers, since installing it I've had lots off trouble with the card not sending a signal to the monitor. Sometimes I have no signal at post then turns on at Vista start up and sometime the other way round switching the monitor off at Vista start up. I've tried 3 different drivers the 190.38 Nvidia drivers are the worst for it. I tried the old one's on the disk and had better luck, now I'm using the 186.18 drivers and the problems back.
I've tried a friends 4890 card in the machine and it's fine and my old card has no problems, anyone else had any problems like this and should I just give up with the card and send it back.
The are some 190.62 which may fix the issues from 190.38 which gave me the same problems as yours, I moved all the way back to 182.5 and it seems fine.
Strange thing is though I have a 275 and as far as I'm aware the 275 didnt even exist when the driver was written. But everything works fine.
