- 11 Dec 2006
I've got a BFG GTX 280 and am very pleased with it. However, recently the fan on it has started to whine and now sometimes fails to start when I boot the PC.
When the fan fails to start, I can get into Windows, but when I start a game, it doesn't take long for the card to overheat (unsurprisingly). When it does overheat, the screen gets switched off and I have to power off get get it running again.
The fan is not completely broken though as if I give it a 'nudge' when it's not running, it does start and works perfectly while the PC is on. Someone suggested cleaning out the dust which I will have a go at (although the card is not that old, and therefore not that dusty).
It could be that the fan will continue to deteriate and stop completely.
Is it RMA time, or is there something I can do to help it work properly again?
Today I switched on my PC and it would not start. After several attempts it booted up and I got into Windows. I started RivaTuner to monitor the Graphics card temps and fan speed and everything was fine.
