- 26 Feb 2007
- Blackpool
Right guys,
whenever i play Left 4 Dead, sometimes it will lock or crash to desktop. Then when i minimize to end process, STEAM will lock.
I stop steam from running and about 2mins later the system will lock and need a hard reset.
Sometimes, i will start my system up and it will get to the desktop but my monitor will flash disconnected. I will then have to hard reset again.
Oh and another annoying one is, i will press shutdown and it will just lock and will require a hard shutdown.
It is ever since putting my new GTX280 it has done this.
I sometimes get a BSOD and it says IRQL not equal etc and then the screen goes black and the system resets itself.
I have run memtest for 9 hours straight and Prime95 and no fails.
I can only think its my GPU. I did a full re-format of Vista x64 when putting my new GPU in.
My GPU isnt overheating and it isnt always locking when under load.
My specs are:
4 x 1gb DDR3 OCZ 2000mhz
Q6600 at stock
XFX 790i Ultra
BFG GTX 280
Tagen 1100w PSU.
Any ideas??? Im puzzled. Could it be the PSU?
My specs are:
Q6600 at stock
XFX 790i Ultra
BFG GTX 280
Tagen 1100w PSU.
