GTX 280 will my system bootleneck?
9 Jul 2008
Bristol
Ok here it goes, i want to upgrade from my 8600GTS 256mb OC LOL
I want to get a BFG GeForce GTX 280 and as there are some deals with OC i want it NOW :P.
I want to know if my system will bootleneck the card as its for PCI E 2.0 and i got a Mobo which only supports PCIE 1 but i heard the 280 is backwards compatible?
Here are my Specs:
Asus Striker Extreme
Pentium E6850 3Ghz
4GB RAM (AData :|)
2 x Raptor 74gb Raid 0
1 x Seagate baracuda 300gb
Geforce 8600 GTS OC 256 MB
what would be the besty 260/280 to get for me? Price range £300 but i would preffer to spend LESS
Shudnt have though that system will bottleneck. What res you running at? The 280s are £260 on OCuk this week if thats what you want, but the 4870 is prob better bang for buck
oh right, sorry read your answer wrong, the only think i am worried about is the PCI-E 2.0
but i do want to upgrade most of my system at the end of the year anyway, just want better graphics for the GAMES now :)
so should i deffently go for it?
I did a test with my 4870 in a v1.0a mobo and then a v2.0 mobo - all other components exactly the same - same fsb/clock - less than 4% difference in benchmarks.
