GTX 460 / DPC Latency Issues
12 Nov 2010
North Wales
Hi,
there seems to be problems with the GTX 460 graphics according to the DPC Latency Checker.
Every 30-40 seconds or so, I get 5 red bars, then it return green for another 30-40, this continues indefinately.
Does anybody know if this is a resolved issue or ongoing?
Many thanks,
Shayne.
What driver set are you using?
I remember there was an issue with 258.96 when the GTX460 first came out, but every other set since then has been fine.
could be your sound card. check its settings.
one way to rule it out disable it in devicemanager and then play the game for 5 minutes then jump out and view dpc latency viewer.
if you use gigabytes easytune thats the problem.
i dont notice any performance difference with easytune running or not though
