GTX 460 Driver Problem - Please Help
23 Dec 2010
Hiya,
I recently bought a new PC with the following specs:
i5 2.8ghz
Foxconn Inferno Katana Motherboard
Asus GTX 460
4gb Corsair 1600 Ram
750W PSU
24" Samsung P2450 Monitor.
I was using my old monitor which is a 17" as i was waiting for my new monitor. Then the day came and i received it, i installed the drivers for it and everything. I restarted my PC then i realised that nothing was working. What i mean is that if i try to start Chess/Hearts/Any game it would not open and Microsoft games would say "No suitable graphic card found". I decided that i should reinstall the Graphic card drivers, i did this and happily enough it worked.
I was able to play games normally....
Until i restarted my PC and same thing happened again. I then reinstalled drivers and it worked until i restarted my PC then same thing..
Please help!!
I am using 1920X1080 resolution.
I have tried installing the most up-to-date drivers i can find.
Running Windows 7 64-bit.
Thanks
Try removing the card and putting it back in first. If that doesn't work, try resetting your CMOS (you will find out where to do this in the motherboard manual).
