GTX 460 Power
THT
THT
10 Mar 2004
I bought a 2nd hand GTX 460 and installed it last night.
On it it has 2 x 6 pin connectors and in the box, there were 2 molex converter to 6 pin cables.
Each of these cables converts 2 x molex -> 1 x 6 pin connector.
I connected just 1 x 6 pin converter cable (which means 2 x molex in) and the card booted fine and ran 3dmark.
Does that mean I really need to connect the other one too?
Thanks
Yes, connect the other one also. It may run fine on 1 for now but you will have crashes/lock ups/bsods possibly if you don't connect the other.
