Hello all,
I'm going WC very soon and will be getting a GTX 470 to replace my 460 Non-Reference card.
As the 470 prices are silly atm, What card do you recommend i should buy to do watercooling with? As it needs to be a reference card.
Also do you think my OCZ ModXStream Pro 600w will be upto the job? Or will i need to replace this also
System Specs:
Intel Core i5 760 2.80GHz @ 4.00GHz
Asus P7P55D-E
Corsair Dominator 4GB DDR3 1600MHz
1x DVD-RW Drive
Swiftech MCP350 10W 12V DC Pump or Swiftech Laing D5 Vario MCP655 12V DC Pump(Still not decided which yet)
2x 500GB Sata HDD's
Creative Sound Blaster Audigy SE Sound Card
Thanks for your time
System Specs:
Asus P7P55D-E
1x DVD-RW Drive
2x 500GB Sata HDD's
room temp was 23.5'c, The Boss had the central Heating ON...
