I'm in the same situation. What would be the minimum PSU requirement for twin 470's? I have a corsair 750w at the mo.
At the moment you'd probably get a 570, you wouldn't see a massive performance leap - but you'd have better acoustics and thermals.
I'm in the same boat, my board only supports crossfire. However, the current batch of games run very well on the card and with an overclocked 470 at 850Mhz, there is very little justification to upgrade to anything else unless you win the lottery and splash on a three 120Mhz NVidia 3D surround rig. For one monitor, upgrading from 470 at the moment would be a bad decision. '
You could try 6870CF for £250, that setup eats a 580 for breakfast. I've been considering my options as I'm due to upgrade my Mb\Cpu\ram, however as I only surf and game on my computer I wouldn't see a great improvement, even going SB 2500K, so was thinking improving the graphics is the way to go.![]()
Yeh, someone needs to come up with a way for both graphics cards vram to be accessable to prolong the life of 1Gb cards in sli\cf. You would have thought they'd(techies) have solved that problem or is there a very simple reason that I'm not aware of.![]()
