- 26 Nov 2009
Would you buy a new EVGA GTX 480 for £75 to pair with Phenom 965?
That isnt an amazing deal when you consider that it is well matched to a GTX660 or a 7850 and you can get those for around that price if you look hard enough.
The heat and power draw of the GTX480 are both mental. I ran mine with an overclock and it sat at 100°C while gaming and sounded like a typhoon.![]()
ha ha you certainly dont want that in your living room - mine seems to run really quiet at the moment but its not been OC'd and not entirely sure its being pushed that hard by Dawn of War lol
The heat from the heat pipes ruined my side window. It had a kind of 'rippled' effect by the side of the GPU where it had been melted slightly...
It also did a good job of heating up the coolant in my CLC at the time.
And I burned myself on those sexy heatpipes a few times too...![]()
If you don't overclock it will probably run 15 degrees cooler though I'd guess.
Its just cos I'm mental.![]()
