GTX 560 Ti
21 Apr 2012
Hi, I have a GTX 560Ti with i5 3470 Ivy bridge cpu. When I play games such as dayz/dota2 it gets overheated very very quickly forcing me off the game before it burns, I opened the case and it was extreamly warm. Any idea what is causing it?
you need to install MSI Afterburner and monitor the temps, from within that program you can also set a custom fan profile to make the fan spin faster to get rid of the heat, remember your case will need intake and exhaust fans as well otherwise the hot air will just sit inside the case.
Are you sure it was the gpu that caused the bsod, what did the dump file say/error code?
70-80 seems okay not brilliant , unlikely to cause instability I don't think.
think it might be the case, when the case is open the temp doesn't go past 70 but when its shut it climbs higher than that. Is it okay to leave the case open to get some airflow or will that cause issues?
