GTX 560ti Overclocking
Permabanned
13 May 2011
I have a Gigabyte GTX560ti with these specs:
900 core
1800 shaders
4008 memory
1037 Voltage
I am trying to overclock with Afterburner to make it equivelent to a Gigabyte SOC card. So i tryed these specs:
950 Core
1900 shaders
4300 memory
1050 Voltage
The card Idled at 26 at auto fan speed and reached 78 max after 17 minutes on furmark. However the furmark test ended after 17 minutes is this a bad overclock? should i try raise the voltage a little more because the temps are fine, im trying to get a 1000 core 2000 shaders and 4580 memory.
Just run a full 3D MArk 06 test no crashes on my OC settings
i dont know about the 560 but my 580 starts messing with me if i let it go above 73c. try setting a custom fan profile in afterburner so it keeps it at about 70c and see what happens.
Furmark is much harder on your gpu than any game thats probably why crysis 2 had no issues.
