GTX 560ti Overclocking
Permabanned
13 May 2011
I have a Gigabyte GTX560ti with these specs:
900 core
1800 shaders
4008 memory
1037 Voltage
I am trying to overclock with Afterburner to make it equivelent to a Gigabyte SOC card. So i tryed these specs:
950 Core
1900 shaders
4300 memory
1050 Voltage
The card Idled at 26 at auto fan speed and reached 78 max after 17 minutes on furmark. However the furmark test ended after 17 minutes is this a bad overclock? should i try raise the voltage a little more because the temps are fine, im trying to get a 1000 core 2000 shaders and 4580 memory.
Just run a full 3D MArk 06 test no crashes on my OC settings
Posting a thread, and then bumping it 20 mins later, and then creating an exact copy of that thread isn't going to help yourself any.
Personally i dont use furmark to check my overclock. I prefer to use MSI Kombuster (i think it is) or i use Heaven 2.5, also to complete other tests, try 3D Mark 11 or 3D Vantage, although the later is quite old now.
I don't know what Gigabyte did to the SOC card but your voltages seem high.
I have:
1000 Core
2000 Shader
2410 Memory
All on 1000mV
Although I do have the SOC
