GTX 560ti problems
1 Jul 2009
I keep having a problem with the graphics card ever since I bought it, a few times a day the screen will go blank and it will say no signal, then a few seconds later it will work again. When in games, the computer will end up rebooting. The temps reach 85 when gaming is this too high?
It could be the TDR issue(driver crashing to desktop), do you have a P/Z67 MB?
http://forums.overclockers.co.uk/showthread.php?t=18338423
My board is a P55. Does that make any difference?
I had this problem on my GPU I solved it by plugging in the monitor lead in the other port on the back of the gpu.
I will try this and see if the problem goes away, thanks.
At first I thought my overclock was to blame, then I had it on factory settings and the display time-out (don't know the technical name for it) happened.
