gtx 560ti
17 Aug 2009
ok then been putting of upgrading my 4870 vaporx but think its nearly time
was wondering if i could run a 560ti on my 500watt power suply
its been running the 4870 overclocked fine
cpu is a i5-750 running at stockspeeds yes i know its a sin
the other option is a gtx560 or a 6870 and before anyone says no i cant streach to £200+ cards
iam using a ocz modxstream 500w
That will be fine.
If you wait, then prepare to wait for a 2012 release as it isn't ridiculously unlikely that that will happen.
I would just get a gap filler card eg GTX 560
if you do decide to go after a gap filler card to tie you over until 28nm has full been depolyed i would suggest going for the gainwood gtx 560ti phantom 2gb.
out of topic but curious, why do people call it "gainwood" when its "gainward" ?
ive seen a couple of posts reffering to it like this.
Overkill for a gap filler card. A standard one will be fine.
I think it's just people not reading properly. There was a thread with gainwood in the title and ever since more and more people have been Calling it that. It's GAINWARD!!!
was looking at the gigabyte gtx 560 oc and the giga 560 ti
will get something for my 4860 so that can part fund it]
but will be hard to move away from my sappire cards 3 out of the last 4 all come from them
Brand really doesn't matter. I had an XFX card as my first card and only wanted to buy XFX from then on but I an guarantee you brand loyalty rarely matters. The only brands I would buy are
MSI
Gigabyte
EVGA
This is because of their excellent RMA
